Hey Guys newbie here, I have a 2001 Honda Recon that I just bought. I was wondering about the reserve fuel tank. Does it mix up with the rest of the tank when I fill up or is it gas that has just been sitting their for a long time I dont want to be out and run out of gas and switch to reserve and suck a bunch of crap into my carb...Thanks Fellas
Welcome to the forums. It all goes into the same tank. There's two tubes that stick up inside the tank. One of the tubes will stick up higher and will be the "on" tube. Fuel enters the top of this tube in the "on" position. When it gets down below the top of the tube, you will run out of fuel and when you put it in the "reserve" position, the fuel will enter a second, lower tube, which is the reserve tube and will finish running all the fuel out of the tank.
