If your quad does not have the option of putting it into 4wd you can. The only time tire size will be an issue is if you have a 4wd machine.
Yeah, I agree with everybody else, you can use them.I have a 2001 ES350 2WD with original 25/11-10 (Rear), 24/8-12 (Front) tires. Can I use 25/8-12's for the front tires or should I stick with the original size ?
Looking to replace with the ITP MudLite tire.....
Tx,
Peppers
