Actually stuck closed! LOL or you have it wired incorrectly. The small wire should get hot intermittently when the start button is held down and then not hot when not pressed.sounds to me like your "new" solenoid is stuck open.
Exactly! Hook power lead ONLY to solenoid. Test other post for power. If no power install trigger and ground, retest. If you have power with key off check trigger lead for power with key off. This lead is supplied power by key switch, after all intetupter safety switches are deactivated/activated as designed by manufacturer. Some use N/O and some use N/C and even combinations of both. I digress, if the trigger is powered when key off, it's time to look upstream for incorrectly attached wiring or defective delivery switchesActually stuck closed! LOL or you have it wired incorrectly. The small wire should get hot intermittently when the start button is held down and then not hot when not pressed.sounds to me like your "new" solenoid is stuck open.
Duh, power to other terminal on solenoid , with only power lead on, indicates defective (stuck closed lol) solenoid. Forgot to include that, my badExactly! Hook power lead ONLY to solenoid. Test other post for power. If no power install trigger and ground, retest. If you have power with key off check trigger lead for power with key off. This lead is supplied power by key switch, after all intetupter safety switches are deactivated/activated as designed by manufacturer. Some use N/O and some use N/C and even combinations of both. I digress, if the trigger is powered when key off, it's time to look upstream for incorrectly attached wiring or defective delivery switchesActually stuck closed! LOL or you have it wired incorrectly. The small wire should get hot intermittently when the start button is held down and then not hot when not pressed.sounds to me like your "new" solenoid is stuck open.
Sent from my SM-G935V using Tapatalk
