If you want a quicker but less elegant solution, and if the cracks are less severe then you can drill holes on each side of the crack and pull the crack together using tie wraps. At the very end of the crack, drill a hole to stop the crack from spreading further.
yah just drill holes and use zip ties
Zip ties is the easy but ugly way... I have done that MANY times
You can also use another piece of plastic under the crack and rivet it to the fenders.
