I have a honda TRX 300 with a metal gas tank and the rear end is broke. I can shift gears and when u give it some gas its just a grinding noise and wont move. Any help would be great
it would be cheaper to replace the ring and pinion. Maybe Helmut can post the instructions because I don't have anyway to post the manual pics.Thanks for all the help I have a question would it be better to replace the whole final drive gear or just replace the ring and pinion
Also how ?
It would be a lot easier to replace the whole final drive, but it would be a little cheaper just to replace the worn gears and bearings. There's a couple special tools that you'll need to get the pinion bearings and pinion shaft out with, though. They can be pretty expensive to buy, but if you're handy with a welder, you can make them yourself.Thanks for all the help I have a question would it be better to replace the whole final drive gear or just replace the ring and pinion
Also how ?
No, the whole final drive just bolts in. You just have to remove the axle and bolt on the final drive and then replace the axle. You don't have to have any special tools to do that as long as you have wrenches to fit the big axle nuts on the axle.Do you need the special tools to replace the whole final drive
Helmut, what suggestions do you have for making the special tool to remove the lock nut for the pinion? I believe I will replace my entire final drive, but I may want to rebuild the old one I have. The pinion locknut is my only obsticale at this timeThere's a couple special tools that you'll need to get the pinion bearings and pinion shaft out with, though. They can be pretty expensive to buy, but if you're handy with a welder, you can make them yourself.
Just find a nut that will fit down into the inside of the locknut and weld it to the end of an impact socket. Make sure the nut isn't so thick that it won't fit over the end of the pinion shaft. If I remember right, I believe the out side of the nut needs to measure 1 7/8 inches across the flats.Helmut, what suggestions do you have for making the special tool to remove the lock nut for the pinion? I believe I will replace my entire final drive, but I may want to rebuild the old one I have. The pinion locknut is my only obsticale at this timeThere's a couple special tools that you'll need to get the pinion bearings and pinion shaft out with, though. They can be pretty expensive to buy, but if you're handy with a welder, you can make them yourself.
