Guys I have a bad exhaust on my 88 foreman. I am wanting to remove it. I removed the mounting bolts and the bolts where it goes into the header pipe. Is there something else I should be doing to make it come off easier?
ebay will be your best bet, or a salvage yardWell thanks for the help. I got it off. I didn't realize there was a hidden bolt behind the frame cover. I put the cobra on and ended up cracking it where the bolt hole is in the front. I may see if I can get it welded. Anyone have a line on a good stock exhaust?
