I had to remove my engine cover to change the starter gears. When i put it back together it won't give me a neutral light. The wiring is correct on it. Focus on these odd symptoms:
No light when key is turned on, e-shifting into reverse gives third gear light. E-shifting into1st gives 4th gear light. So neutral is between 3rd and 4th gear as far as it is concerned.
So what did i do wrong........ i checked and the neutral safety switch is not showing ground. Idk how it could be wrong in there. Can it be improperly seated just by putting the cover back on? I took the switch out and grounded it and still didn't get a light. I also still haven't gotten the main issue of it thinking reverse is third on the indicator and 1st is 4th.
I don't know how this is affecting it, but i believe this is the issue. This pic was when i was testing the stator a month or so ago, but i think this pin is not setting properly.
