I have a 2011 Foreman 4x4 on stock tires (for now). What's the best PSI setup for mud/dirt riding? i'm trying to make these tires last for as long as possible so when I resell them to buy new one's I can get more money for them. Any suggestions are appreciated
I'd guess between 3.5 and 4.5 lbs. Check the manual and just run what it says. As long as you don't run on asphalt then I don't think they are going to wear out too fast in mud and dirt.
Welcome to the forums. I agree with Pain. If you want your tires to last longer, stay off the asphalt. Asphalt will take them down quickly.
welcome to the forums! there should be a plackard on the rear fender with recamended tire pressures if you are running stock run what they say and you will be ok for a couple of years as long as you stay off the blacktop.
