Hi,
My new to me 2007 Electric shift Rancher is smoking like crazy, and it also grinds as it tries to go into fourth gear. Bike has 7000! Miles......I know.....
I had the piston checked at a local bike machine shop, and the head needs to be bored over .30, it will get a new piston and gasket kit and the valves cleaned, ground and re-installed.
Pulled the rest of the motor apart, and now I am looking to replace wear parts.
Would you guys recommend I check all bushings, clutches etc with my micrometer per Honda manual specs?
Also a timing chain would be a good idea to swap at this time?
Anything else? Water pump?
I know I need at least one shift fork, and the 3 rd and 4 th gear kit, #04104-HP5-505 to address the grinding 4 th gear.
Thanks!
Thanks!
