1 - 2 of 2 Posts
hi guys and gals
I have a 2007 recon. that I'm having problems starting in cold weather. i have rebuilt the carb years ago. I'm still having problems getting started in the extreme cold.
i have changed the fuel to ethanol free gas hopping that would help. i still have problems
last year i did replace the spark plug and air filter.
im not sure where to start
thanks again for your time
glen
I can't remember if your carb has the plunger type of choke or the butterfly type. If it has the plunger type then disassemble the carb and clean the jet for the enrichment circuit. You will find a long brass pipe that projects straight down from the plunger hole. This pipe goes into a hole in the float bowl. The fuel enters this hole thru a jet from the float chamber. It is very easy to overlook this jet. It is very small and sometimes hard to clean if clogged. Otherwise if it is the butterfly choke,it is not going to 100% choke.
1 - 2 of 2 Posts
