Can anyone tell me where to get a rebuild kit for a 2007 400 trx ex. I need to rebuild the rear caliper. It constantly rubs as I ride and stays in squeezing the rotor. it never completely releases so the bike runs freely there is always a rub. Is this normal or do I need to rebuild caliper and if so where can i purchase?
bikebandit.com or ebay is your best bet as for rebuilding it..just remove it..give it a good cleaning..lube it up good with some wd-40..see if that don't solve your problem...and when i say remove it..and give it a good cleaning..i mean tear it all the way down..pay close attention on how you take it apart..as you will need this info when you put it back together...lol.
Thanks I will try this
i think you might pump the brake up first then crack the bleed screw if it burps i think you might have a problem with the brake line itself or after you clean it either way
air in the line won't make it rub the rotor..that will just keep it from working period...he needs to tear it down..and give it a very good inspection and cleaning..all the disk brakes i've worked on..always seem to hang up on the floating bolts ( these free float )...they always sieze up..and won't let the caliber retract.
