1 - 20 of 25 Posts
got to bring the rancher to shop makes a grinding/ rubbing noise in rearend when turning to the right took my itp mud lite off and put on my fatory tire wheels on and it 10 x worse ? checked oil ect and nothing loose ?
could be a number of reasons here..first off..i would check your rear brakes..make sure they aren't stuck..second..it could be a bad bearing..if it's not that..then your rear diff bearings are shot..and this will require a complete tear down on the rear diff to replace them.
well with 22 hr and 37 miles on it mostly playing in my feaild and my famlys camp(lil bit of mud) im kinda upset that it s makeing nose ill check rear brakes but it sound like a bearing thare is no water in it as far as i can tell mite just be a bad bearing for fatory i had to call the tuesday for first service anyways so we will see !!!
Yeah, it should have lasted longer than that. It could have been a bad bearing from the factory. They don't hardly put any grease in those sealed bearings anymore.
nope helmut..they don't..anytime i replace any bearings..and they have seals in them..first thing i do is remove them..and repack them full of grease.
Yeah, me too. That's how I know they don't put much grease in them.
been there..done that !..lol.
well guys went out and craked open rear drum only thing in thare was a very goood set of shoe that seem to be working good but when you spin wheel you can fell a bad bearing so honda shop will be getting a call at 8 am on tuesday do to the fact thay are closed sun and monday.
glad you found the problem..and we could help..keep us posted !
Discussion Starter · #12 ·
well dealer said no admormal sounds coming from rear end !!!
lol..shouldn't be any sounds at all comming from the rear end..only time you should hear anything that is normal..is when you are pressing brake petal for rear brakes..now..does the sound happen when you do this with or without the brake drum on ?..if it's doing it when the hub is off..more than likely it's a wheel bearing.
I think the 420 has disc brakes on the rear.
welllllll helmut..i was merly going by what he said..that not read brake drum ??..lmfao.
If I didn't know better I'd think you two were married the way you carry on.. LMAO :icon_ rofl::icon_ poke:
omfg..thats just made my day fourtrax !!!!..rotflmaoooooo!!!
Last time I had noise from the rear-end, the wife made me sleep on the couch...it was a bad seal! Seriously tho, bad bearings. One of my buddies had the same problem, with almost the same response from the dealer. It's almost like they don't want to admit there could ever possibly be a problem with a new machine. Good luck!
Well yeah, I didn't see that. It does say that, doesn't it? I sure thought the 420 had disc brakes in the rear.
OK, I just looked it up, some models do have disc brakes and some have drum brakes. The IRS models have disc brakes and the straight axle models have drum brakes. Sorry about that, Shadetree.
Discussion Starter · #20 ·
well it does have a drum in rear has sra i still here it a lil bit it on my paper that thay gave me with me saying that theres a sound coming from rear end and return paper work says no abnormal sound so if it lets go i can b*%^h them out lol nosie is when im turing hard right, allmost kicking [email protected]@ end out!?
1 - 20 of 25 Posts
