I have a Honda 350 rancher and I am getting a squeaking noise from the back when I am riding. Almost seems to be under the seat.Would this be a upper shock mount bushing wear or lube issue? How do you remove that upper shock bolt. Looks like its difficult to access.
could be the shock bushings, or could even be the swing arm bearings ?
if you can get the noise to happen by pushing down on rear rack to work/move the shocks like, try pin pointing the sound better?
spraying them with some oil, one at a time till noise stops can help you find it too!
Thank you.
