Anyone have tips to removing the brake pedal? I have an 01 Rancher 350. Treat me like a 10 yr old if need be, I'm apparently missing something. Even checked the service manual, and still can't get the pedal off...
because it's rusted on the shaft bro !. couple ways of getting it off ?, depends on how much time you got ?, and energy ?..lol. first..find you some spray lube, blaster or what ever you like ?, I use wd-40. next, round up a 2 lb sledge hammer, or at least a 1 lb ?, ( any hammer will work ? ) the bigger..the faster though !..lol. next, round up a propane torch. you will need this..trust me !..lol. i'm guessing you already have the carter pin out ?, and the outer washer..right ?, next...pry the dust seal out from around the pedal and shaft ( if it's still there ?..lol ). there is also one in the backside ?, but you won't be able to get it off ?..soo..forget about it. now fire that propane torch up ( make sure you get the pastic swing arm caps out !..and any other rubber parts near by moved ! ). heat the crap outta the pedal area right where it sits on the shaft. once it starts to get red hot ?..whack the crap outta it with your hammer. this will knock it down, spray it with lube, hit it back up, rinse and repeat the process..sooner or later the pedal will move freely on its own. once you get it to move easier ?..when working it up and down, be pulling on it outwards...MAKE SURE YOU WEAR GLOVES IF YOU JUST HEATED IT!!!!!. IT'S HOT YA KNOW !..LOL. before long...it will come off
