2013 TRX500 Rear Final Gearcase, slush draining
Just picked up a 2013 TRX500 4x4 SE. Decided to change all fluids, clean filters, plug, etc. . . just to get a base point. All was fine until replacing rear. I removed the oil check bolt, and nusink. I then removed the drain bolt, and nusink. I then added some fluid just to see if I could see some flow, and eventually, some thick sludge finally started to exit the check bolt hole. I then ran out of time. My plan is to check the vent line, flush with diesel, and then re-fill for effect.
I'm not a master mechanic, nor a novice, and I do have the service manual. Just wanting to know if someone is nice enough to tell me if I'm on the right track here or not. Thanks.
