1 - 15 of 15 Posts
no, the drive shaft/drive line is not centered on the trx250 like the trx200 is, they won't line up from the output shaft back to the rear end.
Well just Crush my hopes there shade.... haha. Ok, thank you. Guess I'm going to have to pop the differential open on the 86... ugh...
Sent from my SM-G955U using Tapatalk
might have crushed your hopes ?, but I sure saved ya a lot of time and trouble huh ?!..lol.
Reactions: JustAlex
bad rear diff on your trx250 ?, chances are, stripped ring gear ?, stripped pinion gear ?, stripped axle splines for the ring gear ?. or ??..with a little luck..just bad diff bearings ?.
It's the one I was talking about in another post saying it rolls for a few feet and it will stop rolling but when you jack it up the tires roll just fine shaft spins and everything doesn't sound bad or anything
Clutch adjustment had been mentioned in the other thread/string......
then its one or all of what I said !. time to tear it down, and have a look :).
depends ?. does it not roll while in gear like he said ?, or does it not roll while in neutral ?. clutch adjustment has no effect while in neutral and its doing what he claims its doing ^^^ :).
Discussion Starter · #10 ·
Now I no my hair is short but I'm anatomically a woman shade... lol. Although I am gender-neutral so I don't mind being called a guy. Can a video be uploaded on here so I can show you what it's doing?
the differential of your 250 in the first pic is the same differential used in ATC250ES ( 3 wheeler ) , TRX350D and TRX250A , you can find a diff. on e-bay ------ seal and bearing kits are still available , ring and pinion are not available OEM or aftermarket (yet)
oooppsss..my bad !..lol. what can I say ?..your screen name is alex ?, how many women use the name alex these days ??..lol. i'm sorry alex..pleaseeeeeeee don't tar an feather me !..lol. yes..you can upload a video here.
Discussion Starter · #13 ·
Hahaha... it's all good shade I'm gender-neutral it don't bother me.
1 - 15 of 15 Posts
