So as you all know i've been tearing into the rear end of 300 to install a new axle. After having to cut one of the castle nuts off :icon_twisted: i got both of the hubs off the axle nuts washers etc everything up to the seal of the brake drum and differential. Got the brake drum dust cover off with a little prying and i got in there and seen the drum.:icon_cussing:. It's pretty much screwed. Horrible shape, completely rusted etc etc. I never used the rear brakes for one, they never worked! Im not installing new shoes, drum, springs, brake cam, or any of that junk. It costs too much money to turn around and have the same problem 6 months from now. So i've pretty much decided to find an alternative solution to the problem. I've seen alot of pictures with 300 rear ends without the brake backing plate and drum. How hard of a modification is this operation, and will it provide any benefits or extra guards against water contamination. Im open to all opinions here, but im not putting a fan looking thing to push me through the water in it's place. I'd simply like to keep water out of the rear differential and eliminate my rear brakes all together. Thanks in advance, Tim.
