Okay so I bought an 03 400ex, rear end was all messed up, carrier bearings shot and piece that holds the brake rotor was broke and caliper and rotor were missing. Didn't concern me too much. I ordered just a basic cheap carrier with bearings from eBay that is supposed to fit that year and a new rotor and the piece that holds it. First issue is that the carrier when put in the swingarm sticks out ~1/8" on other side of swing arm so with the caliper holder on, it can slop back and forth. I'm assuming this might possibly be an aftermarket swingarm? I measured against an 01 400 I also have and where the carrier goes through found it to be a 1/4" narrower. Also the spacing seems screwed up on the axle, when I get everything stacked together, it is spaced out just a hair too far to be able to get the circlip that holds the axle nut on. Am I missing something odvious or am I facing a bunch of different aftermarket parts? And how would I ID this stuff to order correct parts.
