Hey guys,
I'm new here and the site looks helpful. I have tried a search but didn't find quite what I was looking for.
My back brakes seem to be locked up. I was told to pull off the rear Drum cover and then tap out the splined rod and it would most likely just have some grit in it and that is why he thinks they are locked up
I removed the tire, the lugs and the plate that they are attached too. Next I removed the several bolts that attach the drum cover and this is where I am having trouble.
The black "metal" cover seems to be stuck on. I tried to get a screw driver in between the plate and the piece it is attached to. I got it in but it seems too hard to pry.
Before I break this I would like to see if I need to do more to make this cover more loose and come off. My friend thinks that the brakes may be engaged against the cover and that may be what is tight.
I am not sure if I have explained this well enough. Basically I want to get into where the brake shoes are but the round black metal cover won't come off and I would love some advice on how to take it off.
Any help will be much appreciated.
Thanks
Thanks
