Been tearing into my stash of rear ends I've picked up for these 300's.
I have 3 350D rear ends, a BR250 rear end that already has a brake delete done, and two 250A rear ends.
Since I'm not a fan of spacers, I'm seriously contemplating getting 350D axle tubes and axle, and using those with the 250A rear ends.
Is anyone actually using rear brakes with a 350D swap? Seems like I saw there wasn't a cable that was the right length.
For those who are doing without brakes in the rear, is there any reason there has to be a drum in there? One of the 250A rears has a backing plate that has a seized cam, no brake pads, and no drum.
The drum cover was in place but no innards. I'm contemplating just boring a hole in the bottom of the drum cover and running it as is.
I've also considered cutting down the backing plate and just doing a delete. Any reason the drum center has to be there, or can I just have backing plate and hub?
Looks like if one is running the brake delete the bearing housing/ backing plate would be very exposed, but then again if water gets in the brake housing you have the same problem and it's worse because the water is sitting in the drum instead of just running off when you get out of the water.
So, what all are y'all doing with these rear end swaps?
