Hey all,
New member here, brand new 1st time ATV owner. Ridden them all my life, finally bought one. It's a 2007 Rancher 420 ES. Just picked it up last week and have spent a few days getting intimate with it. It has 800 miles on it/80 hours, and the PO (original) says it's up to date on it's maintenance, but I'm sort of OCD and anal retentive so I decided to do a service to it so I know where I am at. So I changed the Oil Filter and Oil (Honda 10-30 as per manual), Adjusted the clutch, Changed the spark plug, lubed the cables, adjusted the brakes, and checked the front and rear diff's and antifreeze levels. Air filter was just serviced it looks like (clean and oily) so I think I'm in business and I'm way impressed with it so far. Got it up to 48 before I ran out of road and was scared to try it again...I still had throttle left!
Anyway. I was pushing it into my garage today and felt and heard popping noises. If you hold your hand on the thicker part of the rear axle, right next to diff on left side, as the machine is rolling in neutral/engine off...you can hear and feel it coming from this spot. I've determined it's the axle bearings based on that, and it was extremely muddy underneath and from what I've read the axle bearings are prone to failure if driven in mud/water.
So, the owners manual, although it's good for a lot of stuff, doesn't tell me how to change these. I'm a former car mechanic, and I've worked on lots of machines like this and I can see how to get the axle OUT easily enough, but what about seperating the driveshaft u-joint? And is there a write up out there on how to replace these bearings? Hoping to go hunting next weekend (9/25) so I can order and get the parts overnighted if I can get this apart this weekend. Rear diff was full and clean, so I hope it's just the axle bearings. Also, where would you buy them? I've seen lots of aftermarket suppliers, but haven't used any of them yet.
Thanks! This machine is awesome by the way. I'll likely buy another for my wife. She wants the AT.
Randy
Randy
