yep, ATC is correct, those wires are your carb's float bowl heater wires. unless your in the north pole ??..lmfao..i've never seen a use for them. it will run just fine if you don't fix it, if ya don't fix it ?, at least tape them off, so you wont cause a short in the harness :).
I'd also find away to run those rodents off..... (Moth balls, glue traps, mint spray) cause who knows what they will chew up next.... Been there...
Reactions: rodp
mice will do this too.. i'm getting ready to fire up the propane.. in those holes.. i cant seem to find the valve hose i have as yet.. i like squirrel, an rabbit rodents,, not mice, rats, an moles. i mean to get my revenge..
could be interesting when i fire up a hole.. hope my reflex's are working that day.. even if i get knocked over again, it will be worth it...
Reactions: mrbb
