2006 TRX 350 Battery is at 12.5V when engine is off. When the engine is running it drops to to 11V instead of rising to 13+ V. I tested the stator. It passed the ohm test (0.5ohm all around). I did a diode test on the Rectifier regulator. It passed the diode test. Does anyone have any ideas? I pulled the stator off to see if there was any blackened coils. None. I'm pretty handy, but I'm no expert. Is there any other tests I should run? Any ideas? Thank you for your help.
