21 - 22 of 22 Posts
Hello, everyone! A very good subject is being received, thank you!
To recall the problem again:
The engine works well and accelerates to maximum rpm smoothly and without interruption.
The butterfly valve opens normally, as it should be
Tires are factory-sized, pumped evenly.
There is no brake to hold, no bearing to hold.
My weight is 70 kilograms, I think it's not a problem :D
Only the maximum speed is small.
The machine was purchased from America. If it is used on a farm, can it be limited?
I'm assemble the engine now and putting it on the frame. After all I'm going to do ECU initialize. I hope there is the problem....
Thank everyone and I am open to suggestions :))
I'm still suggesting testing of the shift motor. And video of the top speed vs engine rpm vs gear setting behavior. Once it's back together, of course.
Yea stick with it. Lots of good things on here to check, the more the better equipped you are.
21 - 22 of 22 Posts
