I bought a 01 Rancher ES that the ES isnt working. My guess is the shift angle sensor, as it does not try to shift at all, and doesnt display a gear on the dash.
Are the cheaper Amazon ones okay to buy or is this one of those cases thought shall buy an OEM honda. They are quite pricey from honda.
38800-HN5-A11 is the part number I believe. .
Will a faulty shift angle sensor not show the current gear position? The atv is in neutral, but it shows -- on the gear display. Often is that just a sensor failure, or is there a common mechanical failure on the end of the shift drum that could be an issue?
I bought one off of eBay and Amazon. They were both bad. Kept getting same 22 code so went to local dealer and bought one. It worked good for about 5 hours then did the same thing. Not sure what’s wrong now, getting a 23 code now
