I have a 2002 Rancher 350 and have started to have a display issue. I've tested the battery and even swapped it out with one from my other Rancher.
The oil light stays on while running now too. Starts and runs fine.
https://youtu.be/s8EXEr1rup4
Where do I start?
start with down loading the service manual. it looked to me, it was going through the testing. oil light staying on tells me the oil temp sensor is bad.
Discussion Starter #4
When it runs, the reverse and neutral lights are dim, and the oil light is intermittently on and off.
tells me you have a charging issue, bad stator ?, bad reg/rec ?, bad battery ?.
