Hello, I have a 2011 rancher 420 with auto and power steering. It has a tapping sound from top end which sounds like valves need adjusting. And it smokes white but I can smell oil. Not much or any smoke when idle but when rev high, smoke comes out. I pulled the spark plug out and it was black and oil was on it. I'm debating about doing a top end rebuild instead of bringing to shop and see if that will fix the smoking. I can adjust valves as well. I looked online at top end kits, I would just need to change the piston, rings, clips and gaskets? And have read to change valve seals since I'm there already? Would that fix the issue? The bike has 255 hours and a little less than 1500 miles. Still has power and runs good. The tapping sounds goes away after it's warmed up. Would I need a new cylinder as well? Is a new piston even required? I'm guessing it could just be the rings or hopefully just rings. If anyone has a guide, preferably with photos or a video somewhere I would greatly appreciate it as well. I've never done any work on an atv but have worked on cars. Thank you
Sent from my G8341 using Tapatalk
