I have a 2008 Rancher 420 that is not getting fuel. I can spray starter fluid at the breather and it will run. Stated checking sensors per manual. Everything was fine until I checked the continuity from injector to battery. No Continuity.
Manual says to replace PCM with a good one, so I order one.
Plugged new on in, same thing - no continuity.
The fuel pressure is good at the injector. Took the injector, pushed a stick pin through ground wire so I could leave connector plugged in, connected pin to ground - Injector works.
Put injector back in. I can connected battery ground to pin stick in green wire and it will start and run for a second or two.
I don't know how the PCM works, but I assume a sensor or something is keeping it from providing the ground.
Any suggestions??
Thanks
Any suggestions??
Thanks
