Hi folks,
I am new to the forum and hoping someone could help me diagnose an issue with my ATV. I have a 2009 Rancher 420fe. It is fuel injected and is in good shape with low hours/miles. Two day's ago, I ran out of fuel while tinkering around the house. I reached down and hesitantly switched the fuel selector to reserve. I started it back up (without priming it). I drove forward a few feet and it died again. I figured it was just starved of fuel after running out so I tried starting it again. After giving the starter a workout, I decided to give her an oil change new air filter change and a new plug since I had been putting off that maintenance for awhile and had the parts in the shop. While I was tinkering, I pulled apart the fuel pump assembly and checked the fuel filter and housing for silt/filth. All looked great-greased up the o-rings a bit, added some die-electric grease to the pump's connector and put the small project on hold till morning. Come morning, I put the fuel pump back together and primed it by cycling the key between off and on about ten times. I pressed the start button and it fired up like always. About 20 seconds later, it died. I tried priming it again, gave the starter a work-out and not much worked. I found that it would occasionally start if I gave it some throttle while pressing the start button but quickly died. Other relevant factors: When I turn the key to the on position, I hear the pump runs for a few seconds, and then a buzzing sound for a few seconds. I ordered a replacement fuel filter. It should be here on Monday.
Frequently, I use Sta-Bil and occasionally will throw a bottle of liquid seafoam in the gas tank. Can someone point me in the right direction?....I am a novice diagnostician and a confident parts mechanic....
