Last weekend I installed a Warn XT15 on my new 2016 Rancher. The XT15 is a 1,500 lb winch with 40' of synthetic rope, and a roller fairlead in lieu of a Hawse fairlead. The rollers are aluminum.
I'll attach a pic before I get to my question(s):
So, I made a small unobtrusive recovery point out of angle iron and 3/8" cold roll round stock. I drilled two holes in the angle iron and mounted it to the top of (vertical) fairlead. I fully understand that these rollers should roll. I tightened it up extremely tight so the vertical rollers no longer roll. Made a test pull anchored to a tree with a snatch block and the brakes locked up and it performed flawlessly.
So, the question is, how is having vertical fairlead rollers that don't roll any different than a Hawse fairlead? Am I in danger of damaging the synthetic rope?
The successor to the XT15 is the XT17 which has a Hawse fairlead. The winches are virtually identical.
Please enlighten me one way or another, as currently don't foresee any issues at all. Thank you!
