1 - 13 of 13 Posts
I have a 2014 Honda rancher 420 es. About a month ago I was riding down the road and all of a sudden the motor died and as it was decreasing speed right when it got around 5mph the back tires locked up(still in gear). Well I pulled it home and let it sit for a week or two because I don't have time to work in it. Pulled it out the other day and it won't crank. I pulled the top end off and everything looks good. I'm getting fuel to injector, I got good compression, the plug is firing as normal, I put new gas in it, I chagred the battery and still won't crank. It'll act like it wants to crank sometimes and but never starts up. It'll backfire occasionally when turning over. Any one have any suggestions??
Im assuming by crank you mean it wont start but does turn over....... Pull the air filter and spray some starting fluid down the hole while turning over. If it fires its a fuel problem.
Ant trouble codes, flashing indicator on the display?
Probably no spark. Try running a jumper wire from the battery + to the red and black wire on the coil.
There are several things that can go bad that will cut spark.
Turn key on, yellow engine light on upper right side of the display should light up and go out. If there is a stored fault it will blink....This site has the manual for your bike
http://www.hondaatvforums.net/forum...nual-help/50817-service-manual-downloads.html
SYSTEM DESCRIPTION
SElF·DIAGNOSIS SYSTEM
The PGM-FI system IS equipped with the self-diagnostic system. When any abnormality occurs in the system, the PCMIECM turns
on the MIL and stores a OTC in its erasable memory.
FAil-SAFE FUNCTION
The PGM-FI system is provided with a fail-safe function to secure a minimum running capability even when there is trouble in the
system. When any abnormality is detected by the self·diagnosls function, running capability is maintained by pre-programmed
values in the simulated program map. When any abnormality is detected in the fuel Injector and/or CKP sensor, the fall·safe
function stops the engine to protect it from damage.
MIL Blink Pattern
If the MCS is not avaitable. OTC can be read from the PCMfECM
memory by blink. pattern of the Mil [1].
The number of Mil blinks is equivalent to the main code of the OTC (the
sub code cannot be displayed by the Mil).
The MIL will blink. the current OTC, in case the PCM/ECM detects the
problem at present, when the ignition switch ON or idling. The MIL will
stay ON when driving.
The Mil has two types of blinks, a long blink and short blink. The long
blinking lasts for 1.3 seconds, the short blinking lasts for 0.5 seconds.
One long blink is the equivalent of ten short blinks. For example. when
two long blinks are followed by five short blinks, the Mil is 25 (two long
blinks = 20 blinks, plus five short blinks).
When the PCM/ECM stores more than one OTC, the Mil will indicate
them by blinking in the order from the lowest number 10 highest number.
MIL Check
® ,-c
LI.
'1 .. , ....
111
When the ignition switch is tumed ON, the Mil will stay on for a few seconds. then go off. If the MIL does not come on. troubleshoot
the MIL circuit (page 4·30).
CURRENT DTC/FREEZE OTC
The DTC is indicated in two ways according to the failure status.
In the case that the PCMIECM detects a problem at present, the Mil will come on and will start to blink as its DTC. It is
What caused the motor to lock up?
Discussion Starter · #9 ·
No codes showing. Light does as directed. It has has spark bc I took the plug out and held it against the exhaust and it has fire. Idk this thing has me clueless
If it has spark and won't fire on starter fluid then you have no compression. Either your top end is 100% done or you might have jumped time.
Discussion Starter · #11 ·
It had to jump timing then. Because it has a fairly new top end on it. When I take the plug out and turn the motor over it has plenty of air pushing out the hole
You said the wheels locked up when the motor quit.... that sounds like a seized piston, no?
Air volume isn't a factor... your lungs can do that too, every bit as well or better. Whether the cylinder can build and hold sufficient pressure is the question. Screw a gauge into the spark plug hole, hold the throttle wide open and crank the motor over with the starter for 5-6 seconds to test the cylinder compression.
1 - 13 of 13 Posts
