Hi All,
My first post here,
I've looked and looked and can't find any problems which are exactly the same as the ones that I'm currently experiencing.
I've got a problem with my 2007 420ES, It has been standing for 6 months or so.
When the key is turned on, the following is what happens:
N Green light illuminates to show it is in Neutral
Gear icon flashes - this is no pattern, just a constant and steady flashing
The temp and FI lights briefly come on and then go out
The normal noise heard on ignition isn't there, the bike is silent
The bike won't start or even crank.
I'm hoping that this is related to either the Bank Angle Sensor or Shift Angle Sensor, but both of these failing appear to not be symptoms for the above - the bike will not crank at all, and the gear icon is just flashing.
Please help if you can!
Many Thanks
Alex
My first post here,
Many Thanks
Alex
