Hello, I have a 2003 Honda Rancher 350 which is low miles/hours and has never given me any issues. Today when I went to use it the choke won't move. The knob only travels approximately 1/4 of an inch, if that. Any suggestions? I really need to use the darn thing to drag a lawn tomorrow afternoon. Thanks.
It sounds like either the choke cable or the choke plunger (starter enrichment valve) is stuck? Try squirting generous doses of penetrating oil in the cable while you are operating the lever back and forth (don't force it too hard and break it) and maybe you'll get lucky. You can pressure lube that cable too if you have one. If it is frozen somewhere down near the carb you may have to take the plastics and tank off to grab hold of it and bend it every couple inches or so to break rust loose inside the cable sheath, while you work the lever. Once you get it free, you can use it until your new cable arrives.
You can find a copy of the service manual HERE. Welcome to the forums!
You really shouldn't need a choke in August lol. Try pressing the primer on the carb bowl a few times for good measure and it should fire up just fine without it. As for fixing it, take the enrichment valve out of the carb, if it isn't stuck in there. You'll figure out pretty quick if its the valve or the cable. The valve assembly is about $35, and the cable is around $8. If it were mine I'd just order both anyway and keep any good old parts for spares.
