1 - 10 of 10 Posts
just picked up a rancher 350. Was running good. Took off plastic, changed starter, pull start. Now it cranks and idols fine but won't rev past 4 or 5k rpms. It acts like a rev limiter. Changed plug, cleaned carb. No change. Any ideas?
I tried unplugging the parking brake and jumping it together, didn't change. Its an 05 so I'll have to find a CPU for it to test that. Just bought a factory jet kit. Gonna try going through the carb again first.
I’d check your cdi could be possible because I’ve had multiple atvs sound like there hitting a rev limiter at about half throttle and it always either been parking brake or cdi
Ok this thing has 2 Brian looking boxes, 1 on the rail by the bat and 1 by the steering. Wich one is the cdi?
I know the reg is stacked on the bigger Brian by the bat. But there's another box by the steering about 3×4 inches.
I’m completely lost tbh I haven’t worked on a rancher 350 in quite some time so I’d have to have one to look at to be able to remeber
1 - 10 of 10 Posts
