The breather tube coming out of the head on my 250x keeps on coming apart from the head. It feels llike ir just pushes into place but I am not sure if is it suposed to be fixed inplace or should it be free to move?
Metal peice out of valve cover I can pull it out and slide it right back in. (Job for some JB?)Is it the rubber hose coming off the metal piece or is it the metal piece coming out of the valve cover? If it's just the rubber hose coming off the metal piece, I would just put a hose clamp on it to hold it on.
Yeah, JB Weld will probably hold it. Just clean off any oil first, and let it dry the full amount of time specified and it will probably hold.Metal peice out of valve cover I can pull it out and slide it right back in. (Job for some JB?)Is it the rubber hose coming off the metal piece or is it the metal piece coming out of the valve cover? If it's just the rubber hose coming off the metal piece, I would just put a hose clamp on it to hold it on.
Ok thanks alot!!!Yeah, JB Weld will probably hold it. Just clean off any oil first, and let it dry the full amount of time specified and it will probably hold.Metal peice out of valve cover I can pull it out and slide it right back in. (Job for some JB?)Is it the rubber hose coming off the metal piece or is it the metal piece coming out of the valve cover? If it's just the rubber hose coming off the metal piece, I would just put a hose clamp on it to hold it on.
You're welcome.Ok thanks alot!!!Yeah, JB Weld will probably hold it. Just clean off any oil first, and let it dry the full amount of time specified and it will probably hold.Metal peice out of valve cover I can pull it out and slide it right back in. (Job for some JB?)
