1 - 14 of 14 Posts
I've look in the service manual, as well as, searched online and can't find the answer. Since I'm going to have to buy a special wrench I'd like to get the right one. What is the size wrench you need for the thin nut on a foreman starter. A regular wrench is to thick but I assume most of you guys know that.
Sent from my SM-J327R6 using Tapatalk
send a year, model, and a picture. i used metric, plus had snap-on, tools. their wrenches, are thinner.. i guess also, if you are talking about the one that goes to the positive brush.,, you can hold the battery cable, while you loosen it. 6-pointers work the best..
It is the one you have to hold to loosen the top nut to take the battery cable off. It's a 2000 foreman 450es. I'm sure it's a metric size, as everything else is.
its 10mm. and yes..they dont give you much room to get an open wrench on the nut. your best bet is too grab the cable, CAREFULLY !!!..try to work the nut loose without breaking off the terminal to the starter bolt lead-in !. you do not want to spin the lead-in if you can help it ??!!.
Reactions: LedFTed
If you want to buy a tool that will help you on this problem and others in the future , this little set of mini Vise Grips have come in handy many times for me and will get in to that bottom nut of that starter stud
the ruler makes them look bigger than they are in the pic , the cigarette lighter is a good reference
I had a similar situation and went to a pawn shop bought a cheap wrench and ground it down, cost me a buck for the wrench...
the nut you are talking about, is ultra thin. i had good luck doing it the way shade suggested.. you may have to wire brush the threads, an use a drop of two of penetrating oil
use a good 6-point socket, hold the battery cable, and try to tighten in first, a hair, then loosen, back and forth, many times. if rust has set up, on the bolt, it does take a bit of elbow grease..
1 - 14 of 14 Posts
