Hi there, I have a 2005 trx300ex that decided to lock up on me last fall. So I spent the winter tearing it apart slowly and rebuilding it in my spare time. I found out that the piston rings decided to blow apart and lock the piston in the cylinder destroying the sleeve in the process. Since I cant leave anything stock I decided that a upgrade was in order so I ordered a 330 big bore cylinder for it with a hotshots cam(1058-1). I ended up splitting the case to clean it completely out and started to put it back together. I almost have it together now but I've run into a issue.....when I bench shift the trans I can get it to shift into 1st,2nd,3rd and reverse. It will not shift into 4th. The trans worked just fine before I took it all apart even after the motor quit.
Does anyone know what I may have fudged up or is this normal till the motor runs?
I should probably say at this point that this is the first time I have ever took anything like this apart. (Normally the engine has 8 cylinders to it)
Any help would be appreciated.
Another thing to note is that I was downshifting into 3rd when it locked up on me
