can you put like a 25 in tire on the back and 24 in on the front or can you do it the other way.
What kind of ATV and is it a 2wd or 4wd?
On a 2wd, it won't matter what size tires you have on the front or back, as long as they don't rub the fenders. It might not sit level, though. If it has the same size front and back originally, it would be best to keep it like that, but you don't have to. If you are going to use different size tires, I would use the shorter tires on the front.
