1 - 15 of 15 Posts
hows it going this is my first post, i got a 03 300ex this summer and on the middle of the rear theres a hole that should have a bolt in it [my friends 250 does] he said it needs to be loosened before you adjust the chain my question is since i dont have one there is there a way for water to get into my bearings [i rode at least 3 times a week during the summer and i can move the quad very easy right now with no grinding noise] i just want to be safe so i dont put money into it if i dont have to. thanks ps i go through a lot of puddles here no way to avoid them
no it was a new rear im just wooried about getting water in there.. if i have to get a bolt no big deal but if i did get water in there and not notice it yet i have a friend that chould change the grease and check for me but if i dont have to that would be a good thing
If its a new rear and bearings it may have sealed bearings in witch would be good. Are you talking about the alien head bolts that that you loosen to adjust the chain. If thats it you will be ok but you will need to put a bolt back in to help keep the chain tight.
YOur chain may start getting too much slack in it and if it throws one i've seen them tear up a crank case or bind up all around the front gear.
Ya I know all about that binding up around the front gear. Thats why I had to be toed out of the woods. No Fun! You don't want to bust that crank case.
And your left scratching you head wondering how in the hell did all that chain fit in that little space....lol momentum my friend
1 - 15 of 15 Posts
