ok i asked if i need to bore my bike to put a stage 2 cam but ill go with just high comp piston and stage 1 cam but my bros gettin a stage 2 can for his trx450r would he need to get a high comp piston and valve springs and stuff
If you are having any bogging issues, that is jetting. You should be able to pucnh the gas at any RPM level with no hesitation or bog.
Yes, the stage 1 will increase your mid to top end power. You will have to add lots of fuel. make sure you rejet properly.
