1 - 1 of 1 Posts
Hey guys, I recently bought a Chinese carb for my 1984 atc200s as the float was fecked in my OEM one. So after installing the new PZ27 carb it started leaking from the bottom nipple. So I replaced the jets with the OEM ones but it still leaked. So once again I took it off and this time I thought to check the draining screw a bit better, turns out the chinese one was missing the o-ring on the drain screw, so I just replaced the screw with the oem one and now it is running like a dream with zero leaks! Just thought I'd let youse all know incase you had a similar issue!
Take it easy guys 🤙
1 - 1 of 1 Posts
