There are specs for the tie rod measurements in the service manual, the newer quads with ps have 7mm of thread showing.
First, check the air pressure in the tires to ensure they are correct because a low tire can make it pull. If you need to do a front end alignment, this video will give you a crash course on how to do it at home,
