Hello, new to this forum but not Honda’s. I have a 83 ATC 110 that I have had a shifting problem. The issue is as follows: if the clutch cover is off I can shift thru all the gears smooth as silk. I put the clutch cover back on and I can not shift. I have a service manual and the parts are in correct order and the clutch is adjusted correctly as well. I have read many other post on correct clutch adjustment. Nothing appears bent or broke. I have had the cover off a dozen times now with the same outcome.
