I pulled the front cover and a washer hit the ground. No idea where it was originally I've got a 2015 rancher IRS Dct. Anyone know where it goes?
Discussion Starter #3
The front crankcase cover. I only went deep enough to gain access to the clutches to install a clutch stall kit
The washer could have come from anywhere unintentional and to narrow it down I would suggest getting the service manual and look at the total number of washers when you removed the crank case cover and see if all are accounted for because one may have dropped from somewhere you didn’t see, and hopefully that’s the culprit because I can’t believe it was just tumbling around in there, let’s hope not...
Discussion Starter #7
I found out where it goes. It went on the emergency shifter shaft. At least I'm pretty sure. I was having trouble downshifting think it was hanging up and burnt up my shift motor. Put the washer on there and changed shift motor and it's running like new. Thanks
