This morning, I took my ATC200E you for a ride and it ran fine. Now, it'll turn over only when the engine is cold and once it warms up, it starts backfiring and dies. Once the engine is warm, it won't turn over until its cold again. Here's what I did today.
After my morning ride, I pulled it in the garage and replaced the battery. The new battery was slightly too large for the battery tray so I banged it out slightly so the new battery would fit. After installed the new battery, the engine turned over, ran for a minute then died.
Then, the pull start rope broke so I replaced the rope and reinstalled it. Lastly, I pulled the starter out to see why I wasn't getting enough torque to turn the engine over and reinstalled it.
After doing this work, the engine problems started. I did not mess with the engine or carb.
What would cause the engine to suddenly have these problems. It has to be due to installing the new battery but I'm not sure what. I have the battery properly wired. I only messed with the sides of the battery tray and did not mess with the rectifier or CDI.
