I recently purchased it from someone who finally gave up on trying to fix it.
It will start and run just great for about 15 to 30 minutes and then it just dies like the kill switch has been hit or something. I don't think I have ever got it to start right back up but it has started back up before in as little as a minute later. Though more often than not it will take 15 minutes to a half hour before it will restart and sometimes as long as a day or 2 before it will restart.
I have tried spraying gas into the carb to get it to start right after shutting down and have had no luck with that. I have also checked to see if it has fire right after it shuts down and I do see spark from the spark plug wire with a screwdriver stuck in it and holding it near the engine though it doesn't look like a very bright spark.
Now for the real kicker is I bought a new CDI box for it and I started the ATV several times before installing the new CDI box. Once I installed the new CDI box it would not start at all and even more puzzling is the fact that it would not start after hooking the old CDI back up as well and has not started since. (which has been over a day now)
And before you ask the CDI box that I bought was not a OEM one.
The only other part I have replaced is the fuel pump as I thought maybe it wasn't getting as much fuel as it needed. I saw no need to replace any other parts as when it first starts and runs it does so perfectly.
Any help would be appreciated as it has left me walking on more than one occasion now.
