I'm an idiot. Should have checked this first before spending $195 on a new PCM.
Everything in the shop manual was for troubleshooting a blinking "- -" on the display. Mine wasn't blinking. Got to thinking that maybe it was the Drive gear position switch or a short in the wiring between the GPS and the PCM.
I was getting a solid non-blinking "- -" when in "D".
Did the continuity test starting from the PCM to the 4P connector & then from the 4P connector to the gear position switch plugs. All checked out good.
Took out the Drive gear position switch & swapped it with the Neutral gear position switch (they appear to be identical).
I now have "D", "N" which now has the faulty GPS from "D" lights up either "N" or "- -" if I fiddle with the shift knob I can get it to stay lit in "N" & I got "R".
Got a new Gear Position Switch on order & I should be good to go!
Still have one brand new PCM, still in the box that I can't return. Will sell it for half price to anyone that needs one!
Many Thanks to all the offerred their assistance!
Ol'Roy
Ol'Roy
