1 - 10 of 10 Posts
2000 foreman 450s
any idea why fuel is not flowing from my tank?
When hooked up to the carb, no fuel flows unless i blow into the tank slightly pressurizing it. If i unhook the hose from the carb, fuel flows fine. There is no kinking
any ideas??
Welcome to the forums. Sounds like the float valve in the carb might be sticking, not letting the bowl fill up. When you blow in the tank, the pressure probably pushes the float needle down and lets fuel in. Either that, or your carb vent is stopped up.
When they get trash in them or they were installed backwards it will give problems. glad you got it going
I've seen problems with certain types of inline filters, even when the filters are new. Some will let the fuel flow freely, and some won't. I guess some filters aren't suited for gravity fed applications. Like Moose said, when they get dirty they won't flow well either.
1 - 10 of 10 Posts
