Sounds about right from what i've seen. People have been bashing the old ricer tune up kit so much they say it does nothing.Pipe, filter and tuner will gain some power back. Gear reduction is more cost effective though. All these new guys crap all over the old school pipe/filter/tuner combo but back in the old days before gear reductions it was all we had and we made out just fine.
Mac I think the folks that you say frown on these things, don't frown on them due to they don;t do ANYTHING< its just the costs that are there to have them really isn;t worth the money to most of us, all comes down to your budget I guess??Pipe, filter and tuner will gain some power back. Gear reduction is more cost effective though. All these new guys crap all over the old school pipe/filter/tuner combo but back in the old days before gear reductions it was all we had and we made out just fine.
That's kind of what I was getting at in one of the other threads, these all seem to turn up at once. But back 10-15 even 20 years ago when you did a pipe/filter/rejet you weren't spending a ton of money. But with these newer machines like the OP's 420, the exhausts are only available as full systems not slip ons, and the rejet's are now tuners worth several hundred dollars. So while you can absolutely add power without doing a GR as I said in this thread as well as the other thread it's becoming more and more expensive to do so, and the GR option is much more cost effective. But, on the other hand, people have their own reasoning as to why they might want to avoid a GR.Mac I think the folks that you say frown on these things, don't frown on them due to they don;t do ANYTHING< its just the costs that are there to have them really isn;t worth the money to most of us, all comes down to your budget I guess??Pipe, filter and tuner will gain some power back. Gear reduction is more cost effective though. All these new guys crap all over the old school pipe/filter/tuner combo but back in the old days before gear reductions it was all we had and we made out just fine.
but then again, if you have deeper pockets wouldn;t it just be wiser to buy an atv with more HP from the get go? which is more the point I think us folks make LOL
as smart spending is just that, its not hate from haters LOL just honest advice!
Mac I hear you, a shame simple mods can be so costly as to yrs backThat's kind of what I was getting at in one of the other threads, these all seem to turn up at once. But back 10-15 even 20 years ago when you did a pipe/filter/rejet you weren't spending a ton of money. But with these newer machines like the OP's 420, the exhausts are only available as full systems not slip ons, and the rejet's are now tuners worth several hundred dollars. So while you can absolutely add power without doing a GR as I said in this thread as well as the other thread it's becoming more and more expensive to do so, and the GR option is much more cost effective. But, on the other hand, people have their own reasoning as to why they might want to avoid a GR.Mac I think the folks that you say frown on these things, don't frown on them due to they don;t do ANYTHING< its just the costs that are there to have them really isn;t worth the money to most of us, all comes down to your budget I guess??Pipe, filter and tuner will gain some power back. Gear reduction is more cost effective though. All these new guys crap all over the old school pipe/filter/tuner combo but back in the old days before gear reductions it was all we had and we made out just fine.
If your stuck with Honda's buying something with more power may not be as simple as it sounds. With suspension, weight, gearing other drivetrain differences between all the models, perhaps the larger machines did not suit their needs as well as the Rancher did, or perhaps they didn't anticipate such a power loss with larger tires. I'm only speculating of course.
Don't forget, when it comes to power I'm the guy who buys the most powerful ATV on the planet then goes looking to hop it up and get even more out of it lol
When looking at a 300 build, I've considered doing a 317 kit with a cam, but honestly given the cost vs the benefit, is it worth it?The muffler on the 500 isn't exactly high flow, they are restrictive regardless of what motor they are attached to. Every MFG does the same thing and oddly enough every machine still benefits from aftermarket exhausts. Can-am for example uses the same muffler on their 500 as they do their 1000, double the displacement, same muffler. Both gain HP from an aftermarket pipe.
If you look at an aftermarket exhaust there is very little restriction they are designed to produce more HP. It may only be 2-3hp, but the fact that they do produce more HP is undeniable. Whether they are spending 50 bucks for 500 bucks to do it is irrelevant, it's up to whoever is doing it to decide what there budget is and if it's worth it to them. I can booger weld a $30 tractor muffler onto the stock head pipe and achieve more or less the same result as adding a $500 aftermarket exhaust but it will look like crap and probably rot out in no time vs. the aftermarket stainless steel units.
I'd LOVE to see what their AFR numbers are like running a 55cc big bore and no tuner, must really be something. Your not going to get a boatload of extra power with the Foreman top end. It's a 55cc upgrade but you are still running stock compression and a stock cam. The 420 makes 26.6hp and the 500 28.7hp, the 500 also uses a larger TB BTW. So your looking at what, 8% more power. Nothing to write home about. Bump that compression up to about 12:1 and add a good aftermarket cam and lets here what kind of power you've got then. High Lifter used to offer a 455cc big bore for the 420's that made as much or more power than the 500 kits, less displacement but same or more power because it had some decent compression with it.
99% of the guys doing 500 top ends are doing it because they trashed their stock top ends. I don't think anyone is selling it as a performance upgrade, if they are they shouldn't be.
Yes gear reductions will make a bigger difference. If that's what your looking for. What about for the guy who's on stock size tires looking for more acceleration or someone not looking to loose top end speed. GR's are a great thing, but they aren't perfect for everyone.
I'm not sure what you would consider a substantial gain. Pipe/Tuner/Filter is probably going to add 10% more power pretty easily. That's not too bad really. It's up to whoever is thinking about doing it to decide if it's worth it or not. To me looking at the Honda parts it seems like a bargain. When I did the renegade, the exhaust was about $900, headers $600, the tuner was $1200, ECM reflash $275, and cams were around $650. At the crank I'd be lucky if it added 15hp and it was damn well worth it. $3600+ for 15% more power. vs. the Honda's where you can get 10% for what? $1000 or less?
...a young boy was sitting on Santa Claus 's lap and asked for a pink unicorn , Santa laughed and said there is no such thing as a unicorn , what else do you want , the boy said a Honda with power , Santa said , what color unicorn did you say you want ......I have a 2017 rancher 420 with IRS and ES. I have 27 mega mayhems and the bike bogs down in mud like it has some sort of governor on it. Is there anything I can do to make it turn the tires without a gear reduction?
Way off topic for this thread. Start a new thread, and someone will be along shortly to help you.I have a 2018 Honda rancher 420 and just purchased the sub harness but not sure how to wire up one side has a green wire and white wire with black line and other side has white wire with black line which is positive and with ground want to wire my boss radio to harness?
