I have a few questions if anyone can help me . I have a 2001 trx400ex I did a complete top end rebuild. Ported head 416 cylinder with new piston. Has a power bomb header with a hmf slip on a k&m filter and its jetted . And finished the heat cycle. So the issue I am having with it. When I am in the full throttle it loses all power till I let back off to half throttle then it speeds back up . It will idle fine and take off fine .just on the straight away when I open it up it bogs down .any suggestions will be highly appreciated
Discussion Starter #3
I'm taking the carburetor back apart and see if its clean. What main jet size would your think would help . I'll know the size I have in it right now after I take it out
Discussion Starter #4
Eric
Sounds like you need a bigger main jet or the main jet is plugged with dirt.
I changed the jet have a 152 in it now that fixed the fully open issue.. but now it pops on deceleration. And now it wants to die when I reve it in idle?
